Back to blog
LumenAria Small Terrace 2000 Lumen LED Wall Sconce
Credits to Bellacor
Are you looking for LumenAria Small Terrace 2000 Lumen LED Wall Sconce? We found best price for you. Go to link below to buy the LumenAria Small Terrace 2000 Lumen LED Wall Sconce for the lowest price.
LumenAria Small Terrace 2000 Lumen LED Wall Sconce Review
It's another awesome product from Justice Design Group. You cannot go bad with this purchase at Bellacor .
LumenAria Small Terrace 2000 Lumen LED Wall Sconce Description
- Dimmable LED is now a lamping option for thousands of wall sconces, semi-flush bowls and flush-mount products offered by Justice Design. The light quality is warm (3000K) and truly stunning. They are dimmable down to 5 percent and work on a variety of dimmers, including standard electronic dimmers. Not only are these fixtures energy efficient, consuming the equivalent of a 75W incandescent bulb (1,000 initial lumens) per LED, but they are rated for 50,000 hours ? which means no more climbing ladders to change light bulbs! The LED engine comes standard with a 5 year warranty. - Color Rendering Index: 85 - Beam Spread: 120 - Total Wattage: 26 - Electrical: Input Frequency: 50-60 Hz. Power Consumption per Light Engine: 13W Dimming: Compatible with Incandescent / Triac or ELV Dimmers. Driver Efficiency: Greater than 80 percent - Illumination and Efficacy: Light Output Per Engine: 1000 Lumens (Initial) . Light Engine Efficacy: 77 Lumens Per Watt (Initial) . ANSI Binning: + / - 175k MacAdam Ellipse: 7-Step CFL Equivalent: 18W per EngineDimmability: Down to 5 percent Beam Angle: 120 Ambient Temperature Operating Range: -20C to +40C ( -4F to +10F) . EPA Compliant - 2,000 initial total lumens, the equivalent of two 75 watt incandescent bulbs Justice Design Group - FAL-2225-LED2-2000
