Are you looking for SkyScan Ti-plus Multi-Function Heat Index Wa? We found best price for you. Go to link below to buy the SkyScan Ti-plus Multi-Function Heat Index Wa for the lowest price.
SkyScan Ti-plus Multi-Function Heat Index Wa Review
I recommend buying XTREME RESEARCH SkyScan Ti-plus Multi-Function Heat Index Wa .It has some nice quality and it's definitely worth 140.79
SkyScan Ti-plus Multi-Function Heat Index Wa Description
The Ti-plus multi-function instrument features an easy to read arrow display showing all ranges of dangerous heat conditions. Audible warning sounds before heat index reaches critical levels. Danger icon is always present during dangerous conditions. Other functions include: accurate display of actual temperature in both Fahrenheit and Celsius, as well as relative humidity and heat index. New type automatic operation makes other models obsolete. No water, twirling or charts are necessary. Critical information is stored in memory for 24 hours and can be re-displayed. The Ti-plus also functions as a countdown timer, stopwatch and alarm. SkyScan Ti-plus Features: 24 hour memory. Stopwatch & timing device to .000 seconds. Large, easy to read digital display. Ergonomic design fits in the palm of your hand. A soft carrying case (included) . Includes lanyard. Displays temperature, relative humidity and heat index. Timing alarm & audible alert. Powered by a single wafer battery (included) . Includes controls for a calendar (month, date, & year) . Includes controls for a clock (hour, minutes, & seconds) . Includes controls for an alarm clock (alarm on, alarm off, & snooze) . Includes on/off controls for audible alerts
Related posts
- DynoJet Multi-Function Hub Accessory With Multi-Select For Power Commander USB
- Kohler K-968-BN - Multi-Function Showerhead
- The Orleans Multi-Function Storage Unit
- KOHLER K-72418-BN - 3-9/16 Three-Function Multi-Spray Showerhead 2.0 GPM
- Adjustable Multi-Function Shop Stand Legs
- Kohler K-10286-SN - Four-Function Multi-Spray Handshower 2.5 GPM
- Kohler K-10284-G - 5-15/16 Three-Function Multi-Spray Showerhead 2.5 GPM
- Kohler K-10597-SN - Four-Function Multi-Spray Handshower 2.5 GPM
- Veridian Multi Function Pocket Digital Pedometer
- Graff G-8674-SN - Contemporary Multi-Function Handshower
- Kohler K-16167-CP - 5-15/16 Three-Function Multi-Spray Showerhead 2.5 GPM
- Kohler K-10286-2BZ - Four-Function Multi-Spray Handshower 2.5 GPM
- Kohler K-18495-CP - Four-Function Multi-Spray Handshower Head 2.5 GPM
- Kohler K-10298-2BZ - Four-Function Multi-Spray Handshower Head 1.75 GPM
- Kohler K-99242-CP - Multi-Function Wall Mount Slidebar Handshower Kit 2.0 GPM
- CURT Trailer Wiring Adapters 57102 Multi-Function Sockets
