Are you looking for Tube Architectural 5-Inch LED Double Wall Light Shines Up and Down 3000K in Graphite? We found best price for you. Go to link below to buy the Tube Architectural 5-Inch LED Double Wall Light Shines Up and Down 3000K in Graphite for the lowest price.
Tube Architectural 5-Inch LED Double Wall Light Shines Up and Down 3000K in Graphite Review
When you are looking for fast and special wall lights, that is something for you. Nothing is better at this particular 450.00.
Tube Architectural 5-Inch LED Double Wall Light Shines Up and Down 3000K in Graphite Description
- Precise engineering using the latest energy e? cient LED technology with a built-in reflector for superior optics; An appealing cylindrical profile perfect for accent and wall wash lighting. - Solid Aluminum construction, high performance facade LED wall mount light. Available in customizable specs, including light direction (Straight up or Down, Away from wall, or Towards the wall) . - Energy Star Efficient, CEC Title 24 Compliant (90CRI Versions) . - Smooth and continuous dimming with an electronic low voltage (ELV) dimmer, or equipped with optional 0-10V Dimming. - Driver located inside outlet box, driver is universal input ready for (120v-220v-277v) . - Replaceable High Powered LED Module, CRI:85-90, Color Temp: 2700K - 3500K, 80,000 Hours Rated Life. - Bulb Shape: LED Module - Beam Spread: 58 - Rated Life in Average Hours: 80000 - Shade Glass: White Glass Diffuser - Shade Material: Glass - Shade Color: White - Hardwired - Warranty: 5 Years Functional, 2 Years Finish - Bulb (s) included. WAC Lighting - DS-WD05-F30S-GH
Related posts
- Tube Architectural 6-Inch LED Double Wall Light Shines Up and Down 3000K 90 CRI in Graphite
- Tube Architectural 8-Inch LED Double Wall Light Shines Up and Down 3000K 90 CRI in Graphite
- Tube Architectural 8-Inch LED Double Wall Light Shines Towards Wall 3000K 90 CRI in Graphite
- Tube Architectural 8-Inch LED Double Wall Light Shines Towards Wall 3000K in Graphite
- Tube Architectural 6-Inch LED Double Wall Light Shines Up and Down 3000K in Black
- Tube Architectural 8-Inch LED Double Wall Light Shines Up and Down 3500K in Graphite
- Tube Architectural 6-Inch LED Double Wall Light Shines Up and Down 2700K 90 CRI in Graphite
- Tube Architectural 5-Inch LED Double Wall Light Shines Up and Down 2700K 90 CRI in Graphite
- Tube Architectural 6-Inch LED Double Wall Light Shines Up and Down 2700K in Graphite
- Tube Architectural 5-Inch LED Double Wall Light Shines Towards Wall 3000K 90 CRI in White
- Tube Architectural 6-Inch LED Double Wall Light Shines Towards Wall 3000K 90 CRI in White
- Tube Architectural 8-Inch LED Double Wall Light Shines Towards Wall 3000K 90 CRI in White
- Tube Architectural 8-Inch LED Double Wall Light Shines Towards Wall 3000K 90 CRI in Black
- Tube Architectural 6-Inch LED Double Wall Light Shines Towards Wall 3000K in White
- Tube Architectural 8-Inch LED Double Wall Light Shines Towards Wall 3000K in Bronze
- Tube Architectural 6-Inch LED Double Wall Light Shines Towards Wall 3000K in Bronze
